Offroad & 4x4
Open Differentials
Old Sep 27, 2005 | 08:37 PM
zman764's Avatar
zman764
I am under the impression that in my truck the front axle is always spinning, theres no hubs, and when u engage 4x4 it simply connects the driveshaft, Wouldnt this make it impossible/bad to have any type of locking diff. in the front?
Old Sep 27, 2005 | 08:57 PM
chrono4's Avatar
chrono4
not positive, but im pretty sure you have auto hubs, vaccum actuated when you put it in 4 wd. but im sure someone will know for sure.
Old Sep 27, 2005 | 09:18 PM
BFR250SD's Avatar
BFR250SD
If your front CV's are always spinning the only good option you'll have is a selectable locker. This will run more bucks than you probably want to spend. You're looking at upwards of 600 - 900 dollars depending on what you get.
Old Sep 27, 2005 | 09:48 PM
82F100SWB's Avatar
82F100SWB
The 97+ F150's do not have hubs of any sort, it's a CAD setup.
Definatley do not want an auto locker or a spooled/welded diff in the front.
Old Sep 27, 2005 | 09:54 PM
zman764's Avatar
zman764
can you explain what the CAD setup is in more detail?
Old Sep 27, 2005 | 09:56 PM
fishmanndotcom's Avatar
fishmanndotcom
center axle disconnect, your axle disconnects from the driveshaft at the diff
-cutts-
kupaa
Oct 19, 2010 03:05 AM
Fomoko1
Apr 23, 2006 10:28 PM
timberwolf-man
Offroad & 4x4
25
Dec 14, 2005 02:13 AM
jowilker
Sep 2, 2002 06:10 PM
theleetbeagle
Sep 13, 2001 03:52 PM
