1978 - 1996 Big Bronco
Another 94 Bronco question
Old Sep 24, 2005 | 07:53 PM
mrfixitII's Avatar
mrfixitII
I asked a question and got such a great response, I thought I would ask another one. I replaced the radial arm bushings because one was completly shot to hell. Here is the question. How tight do they need to be? Is there a certain tourqe? or do I tighten them as tight as I can????
mrfixitII
Old Sep 24, 2005 | 11:39 PM
Tazz452's Avatar
Tazz452
My Haynes book doesn't state a certain torque that I could find, so I would imagine pretty darn tight, drive for about 100 miles and recheck. Also it states that a new stud and bolt are required on 4wd models because of some adhesive coating on the oem part. If not available it says to clean thoroughly and apply loctite to the threads.
Old Sep 25, 2005 | 12:06 AM
Tazz452's Avatar
Tazz452
I found some more info about torque on the radius arms. Problem is it depends on which bolts. I then went to autozone.com try this link (click on pix for exploded views and torque settings): http://autozone.com/servlet/UiBroker...3d800a7f09.jsp
Old Sep 25, 2005 | 12:12 AM
greystreak92's Avatar
greystreak92
OEM specs are between 80-120 ft-lbs. on the nut at the end of the radius arm.
The upper stud/bolt is 240-260 ft-lbs.
The lower bolt is 320-340 ft-lbs.
Old Sep 25, 2005 | 11:52 AM
mrfixitII's Avatar
mrfixitII
Thanks guys, I really do appreciate the help
mrfixitII
