Modular V10 (6.8l)
rev limiter
Old Sep 24, 2005 | 06:08 PM
02q45's Avatar
02q45
rev limiter
I noticed that when I hit the rev limiter the battery light comes on, is this normal?
Old Sep 24, 2005 | 09:30 PM
NoMo's Avatar
NoMo
Not normal. Your belt may be slipping at high RPMs.
Old Sep 25, 2005 | 06:19 PM
02q45's Avatar
02q45
I used some belt spray today and problem solved. thanks
Old Sep 26, 2005 | 12:27 AM
NoMo's Avatar
NoMo
Glad that was it! But, the use of "belt dressing" is, at best, a temporary fix. Buy a new belt and keep the old one in the truck as a spare- in case something happens out on the road.
Old Sep 26, 2005 | 09:51 AM
02q45's Avatar
02q45
ok I will do that.
Old Sep 26, 2005 | 10:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Early V10's were known for this, probably '99 up through '03 or so... My '01 did it too.
It would love to screech at the 1st-to-2nd shift.
Get a "toothed" belt - not one like the stock Ford one with continuous ridges.
Dayco makes one, and I'm sure Gates makes one.
Check your tensioners while you're in there too, if they are AT ALL loose, change them right away.
art k.
Old Sep 26, 2005 | 04:24 PM
02q45's Avatar
02q45
this is a 04 V10 with 25,000 miles.
