Electric cooling fan
Old Sep 24, 2005 | 01:47 PM
Wolfdog's Avatar
Wolfdog
Hi,
has anyone got for the 2004 5.4L truck an electric engine cooling fan installed? Any experience? Where did you buy it? Difficult installation?
Thanks
Old Nov 6, 2005 | 12:27 PM
JKirkes's Avatar
JKirkes
I purchased a Flex-a-lite dual unit for my 05 5.4L. Don't remember the exact model, but the tech support at Flex-a-lite can tell you what unit will fit yur app.
When I purchased mine he said they have only tried it on the 03 models, but he felt that it would work on the 04 and 05 models as well. Guess what he was right. It bolted up very nicely with zero modifications. The biggest problem you will have is finding a switched 12v power on.
Better late than never, hope this helps. If you need details I will dig a bit more.
Old Nov 7, 2005 | 01:37 PM
Wolfdog's Avatar
Wolfdog
Hey, thats good news!. Thanks for the reply. I will look into this. Where did you get the switched 12V?
Old Nov 7, 2005 | 06:08 PM
JKirkes's Avatar
JKirkes
I used the same 12v on as the AC clutch compressor relay does. There is a relay box under the hood on the driver side fender. I tapped into the wire as it exits underneath the relay box. If you look in you owners manual there is a diagram describing what relay does. I don't recall the color seems like it was red and yellow.
Hope this helps.
Old Nov 7, 2005 | 07:12 PM
Quik Truk's Avatar
Quik Truk
I installed the dual 16" electrics<!-- from Mike T ----->.They were built for the '04-'05 F-150's and come complete. They are a very easy install..
Old Nov 8, 2005 | 11:01 PM
Carguy1959's Avatar
Carguy1959
Just wondering, why are you guys installing cooling fans on your trucks?
Old Nov 9, 2005 | 04:22 PM
JKirkes's Avatar
JKirkes
There are a few horses to be had by replacing the stock clutch type fan with an electric setup.
Old Nov 9, 2005 | 05:49 PM
kd4crs's Avatar
kd4crs
JKirkes,
Was the unit you used the Flexalite 270? I have been thinking about getting one of those if it is a direct bolt on. Thanks.
Old Nov 9, 2005 | 07:37 PM
JKirkes's Avatar
JKirkes
Yes, it was the 270. Very good product. Any questions let me know.
Old Nov 9, 2005 | 07:54 PM
JKirkes's Avatar
JKirkes
kd4crs
I have been through a lot over the pat six months, Flex-a-lite electric fans, JBA headers, Magnaflow hi flow cats, Banks cat back, Volant cold air intake, Hughes torque converter, TransGo shift kit, Motive Gear 4.56 gears, Nitrous express setup, FJO wide band AFR, Auto Meter fuel and nitrous gauges, and finally a custom tune. What's next head work and a set of cams once comp releases the 3V version.
I have expierenced the ups and downs and finally have got it all together. Primary problem is finding a reliable source that knows what is compatible with the 04-05 models.
If I can be of any help please let me know.
Thanks
Old Nov 9, 2005 | 08:02 PM
JKirkes's Avatar
JKirkes
Oh and by the way if you go with the electric fans it eliminates the fan shroud. This makes replacing the oil filter a piece of cake. Nice benifit.
Old Nov 9, 2005 | 08:42 PM
kd4crs's Avatar
kd4crs
JKirkes,
Where did you get your Fleaxalite 270? Thanks for the information.
Old Nov 9, 2005 | 08:58 PM
JKirkes's Avatar
JKirkes
Got it from Summit Racing. It is a complete kit and bolts right on.
Old Nov 9, 2005 | 09:04 PM
kd4crs's Avatar
kd4crs
JKirkes,
That sounds like what I'm looking for. Thanks again for the information.
Old Nov 15, 2005 | 06:29 PM
JKirkes's Avatar
JKirkes
Sorry if I have already replied, but I got it a summit racing.
