79 axle into 70
Old Sep 23, 2005 | 02:49 PM
Broke n' Down's Avatar
Broke n' Down
79 axle into 70
My king pin bearings are getting pretty sketchy in my 70 F250 4x4 and since I'm having trouble finding new ones, I thought I would look for another axle to 'throw in.' I found a 79 F250 with a good front end that I can get for free. Has anyone done the swap to a reverse rotation dana 44. All I know is that the measurements are pretty close for the springs, and that the steering arm will work with a little adjustment. Any thoughts would be appreciated.
Old Sep 24, 2005 | 04:54 AM
jowilker's Avatar
jowilker
BnD, Have you thought about moving your sheet metal over to the 79? The diffs need to be matched. The engine & trannys may not match, but can be swapped. Your 70 would have a FE and they were last used in 76. The 79 would have a 400 if they both have big V8s. If the trucks have 6s or 302s they will be the same.
You'll figure something out, I'm sure.
John
