Need help identifying brake rotor
Old Jul 17, 2002 | 10:42 AM
bbtkd's Avatar
bbtkd
Hello - I have a 1973 Ranchero which apparently does not have the factory disc brakes on it. I had a rotor go bad, so I ordered a new one. But it was incorrect. The ones that are on it are 10 3/4" while the ones specified for it (and years around it) are 11". The inner bearing is also larger on the ones that are on the vehicle. I need to try to identify what vehicle mine came off of, since they are apparently not factory.
So - I am looking for the year and model of Ford which took 10 3/4" inch front disc brake rotors. Numbers on the rotor are "1120" and "816028". Not sure if those are Ford numbers or aftermarket. With the low mileage of the truck (~50k), I suspect they are Ford originals. Thanks!
Old Jul 17, 2002 | 02:39 PM
hawkrod's Avatar
hawkrod
74-74 intermediates had 10 3/4 and 11 inch rotors go back to the parts store and ask for 74 ford torino rotors and they should ask you what size. hawkrod
Old Jul 18, 2002 | 08:23 AM
goodfoot's Avatar
goodfoot
Check the lug pattern also, the smaller rotors are frequently not a 5 x 5 1/2" std. Ford truck wheel pattern.
Old Jul 18, 2002 | 08:40 AM
jcs17's Avatar
jcs17
