2000 Explorer will not idle
Old Sep 23, 2005 | 01:24 PM
robotdoc's Avatar
robotdoc
We have had this problem in the past but it went away after an hour. It is a 2000 Explorer with 4.0L/5 speed Auto
The explorer will operate normally, but will not sustain an idle. I am out of warranty coverage and would like to repair this problem myself.
Any thought's as to what is causing this? My thought was the TPS.
Thanks in advance.
Old Sep 23, 2005 | 01:31 PM
rpm5099's Avatar
rpm5099
I just replaced my Idle air control valve on an 02 4.6L explorer. I would assume that your explorer has the same part. Mine was making a rattling noise under the hood for the past year that I never noticed. The fix is under $100 and takes only a few minutes. Its worth checking out. You should have already done the regular tune up steps before you try this though.
Old Sep 23, 2005 | 01:37 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
