Front wheel bearing replacement
Old Sep 23, 2005 | 12:47 PM
windsorharley's Avatar
windsorharley
I need to replace the front wheel bearings in a 1993 Ford F350 pickup w/4 wheel drive and I want to see a diagram of the proceedure. Is there somewhere I can get something like this on the internet?
Thanks,
Bob
Old Sep 23, 2005 | 01:25 PM
Lazy K's Avatar
Lazy K
Search these forums for info., but it is not difficult. Lift brake caliper away, remove freewheel mechanism if any, then using four prong wrench remove wheel bearing lock nut and remove hub. You can then knock out old outter bearing races and tap in new and install hub with new inner races. Tighted lock nut untill all play in hub just disappears having packed new bearings with grease. Nothing to it.
Old Sep 23, 2005 | 01:52 PM
andym's Avatar
andym
I would pass on replacing the races unless they are blued, scarred, showing copper, or otherwise damaged. If they are worn, then at least they wear evenly. Any slack is removed when the spindle nuts are tightened. If you replace the races, you run the risk of screwing them up during install (it's easy to do) and then you have to do the job all over again.
low92flareside's Avatar
low92flareside
Hayne's manual has a great blown apart diagram of this procedure. Hayne's manuals available at most auto parts stores and always a worthy investment. Lots of great info in there.
WRC
Bronco II
Jul 11, 2015 11:30 PM
Brick Bob
WTB - Parts & other
May 16, 2015 05:15 PM
7622RM
1983 - 2012 Ranger & B-Series
Feb 21, 2015 08:37 PM
Corkwheats
Feb 12, 2015 06:01 AM
bob6202
Jun 18, 2013 07:26 AM
