Sponsored by: Real Truck
superchips tuner
Old Sep 23, 2005 | 12:44 PM
Bigford99's Avatar
Bigford99
superchips tuner
Quick question has anyone had any problems the the superchips tuner causing a few DTC's to come up. particularly these (04-p0232, 03-p0603, 02-p1316, 01-p0344) any info would be greatly apreciated
Old Sep 28, 2005 | 10:53 AM
Wings's Avatar
Wings
I don't have a Superchips tuner, but I do know that you can reverse the programer to your stock setting. P0232 is Fuel Pump Secondary Ckt High, P0603 is a PCM Memory error, P1316 is INJ Driver Module code Detected and the P0344 is the Camshaft Position Sensor, Bank 1 CKT Intermittent. If you can clear the codes and try another reading, I am betting you will only get P0344, this code is most likely one you will want to pay attention too. Your CPS is ready to take a dive. Happened to me. I would also contact Superchip reguarding the other codes. Good Luck
Old Sep 28, 2005 | 11:16 AM
02PSD4ME's Avatar
02PSD4ME
P0603 is a PCM Memory error, do not worry about this. You get this when you reprogram the compute (using the programmer) and if you disconect your batters.
