Check Engine light stays on
Old Sep 23, 2005 | 11:49 AM
bchunter's Avatar
bchunter
I got my truck from my dad not too long ago and he had the cat reemed out and put a different muffler on it (I am not sure of the brand). The check engine light comes on and stays on when the codes are read and cleared. It refers to the cat (I can't remember the actual code, it is on the bill at home) and it comes on since the cat has been reemed out. I have a spare 3" exhaust with a flowmaster muffler on it that I am going ot put on this truck at some point and not have the cat. I can get an adapter from Flowmaster that puts the 2 exhaust pipes from the manifolds into one 3" outlet, and the guys from the shop say that they can incorporate the O2 sensor into it.
My question is is there a way that I can keep the check engine light from comming on right now, and secondly, will it stay on or will I be doing any harm when I replace the exhaust system with no cat? Can I have it reprogramed so that the light does not come on if there is no cat at all?
Thanks for the help.
Old Sep 23, 2005 | 12:40 PM
Silver Streak's Avatar
Silver Streak
Yes, the light is because the cat is gone. There is an O2 sensor downstream of the catalyst. When that sensor starts reading the same as the upstream O2 sensor it tells the computer that the catalyst is no longer working efficiently. The only way to truly repair the problem is to replace the cat. There are many bandaid fixes, including installing a simulator in the downstream O2 sensor wiring. I would just replace the catalyst with an aftermarket part. A good cat won't hurt performance any.
Old Sep 23, 2005 | 01:24 PM
bchunter's Avatar
bchunter
Thanks for explaining how this works. I did not know that there were two O2 sensors. So can I replace this system with the other exhaust and just have 1 O2 sensor, or will I really goof up the computer?
Old Sep 23, 2005 | 02:43 PM
Silver Streak
The puter needs a signal from both O2 sensors to know that the cat is working properly.
Old Sep 24, 2005 | 08:05 AM
Motorhead351's Avatar
Motorhead351
One of the quirks w/t the 96 mass air, gotta love it.
Old Sep 26, 2005 | 10:13 AM
bchunter's Avatar
bchunter
What do you guys recommend for a good freeflowing cat? So I guess my best bet would be to get a good cat then put the exhaust system that I have from the cat back.
Old Sep 26, 2005 | 01:06 PM
Motorhead351
Sounds like a plan, good luck
Old Sep 26, 2005 | 01:39 PM
frdtrkman's Avatar
frdtrkman
Have the shop put both sensors close together so they will have the same readings and you wont need a cat.
Old Sep 26, 2005 | 02:41 PM
Silver Streak
Putting them close together so they read the same is the exact wrong thing to do.
Old Sep 26, 2005 | 02:43 PM
frdtrkman's Avatar
frdtrkman
Really? Why?
Old Sep 26, 2005 | 02:44 PM
Silver Streak
That's why.
Old Sep 26, 2005 | 02:54 PM
frdtrkman's Avatar
frdtrkman
oh. I misread that part.
