Modular V10 (6.8l)
V-10 Storage
Old Sep 23, 2005 | 11:02 AM
Big Rig's Avatar
Big Rig
V-10 Storage
Guys/Gals,
I'm leaving for TX on 9/27/05 for 4-6 months to help out Farmers Insurance with Hurricane Rita. I'm a Branch Claims SPVSR in Lexington, KY and they need my help down their. I am taking my entire family with me.
My ? is this. I'm leaving the Ex behind. What should I do to her to make sure she's ok when I get back. I do not want to leave the keys with anyone as my neighbors like this car and all have the BSEG for the V-10 but nobody owns one except for me. She won't be driven for 4-6 months like I said.
Any help will be appreciated. I hate to leave her behind..I'm gonna miss her..
Big Rif
Old Sep 23, 2005 | 01:37 PM
ford390gashog's Avatar
ford390gashog
i would change the oil to prevent acid build up. add fuel stabilizer and remove the battery or batteries. thats about it.
Old Sep 23, 2005 | 01:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
Will it be garaged?
Old Sep 23, 2005 | 04:14 PM
ken04's Avatar
ken04
Originally Posted by Big Rig
Guys/Gals,
Big Rif
I'd throw in some Sta-Bil, drive it around for a few minutes to mix it up and get it up into the fuel pump/injectors and park it. Spray some tire black on the outside and inside of the tires, give her a good coat of wax without buffing it off, throw in a couple dryer sheets (mices and bugs hate em) on the floor, maybe make sure the anti-freeze is up to snuff, pull the wiper blades off the windshield and call it good.
Upon your return change the oil and go. 4-6 months aint long, if I had a maintenance-type battery charger I may hook it up. But not one of those 1 amp thingies, even those will boil your battery dry. If it's going to be in a cold climate you'll want to keep your battery charged or it will be no good when you get back.
Old Sep 23, 2005 | 07:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Everyone else very good pointers. One thing no one mentioned, fill the gas tank.
While I doubt the gas stabilizer thing, do it anyway, it can't hurt. I would drive it until the low-fuel light comes on, and then refill with brand-new gas (if you can afford it).
Everything else should be good.
Some people are **** enough to put it on blocks so the tires are not sitting in one spot too long. That's up to you
art k.
ps: My response about gas stabilizer is based on years of experience with gas left in tanks... but never fuel-injected motors. The last 10-15 years, the gas is already conditioned enough that it won't varnish within 6 months. I've left gas in my '74 highboy for 5 years, it started right up and ran fine. My '89 Honda NX650 (Enduro bike) never gets drained, the petcock is left open, and no buildup of varnish anywhere. And the tanks are spotless. Anyway...
Stabilize it anyway, it can't hurt - but like I said, fill the tank to the top (to keep condensation down) with brand-new gas after running it down to empty.
Old Sep 23, 2005 | 09:29 PM
BFR250SD's Avatar
BFR250SD
My truck is on it's second iteration of sitting for 6 months now. Prertty much do what is stated above.
I washed, waxed it, cleaned the interior and used lysol, put Sta-bil in the tank, changed the oil, removed the battery, put the sun shade in the front window and put a rag in the intake to keep the critters out.
Got home the first time, put in the battery and took out the rag. It fired right up.
Old Sep 24, 2005 | 04:56 AM
captchas's Avatar
captchas
Guest
i would go to a marine store and get a big bottle of store and start. it's a fuel stabilizer and fogger in 1. coats the valves and cylinder walls to help stop rusting. fill the tank. drive it a while, do a oil change. get the wheels and tires off the ground to stop flat spoting the tires. every one else has great points.
best of luck and please be safe
Old Sep 24, 2005 | 07:24 AM
Big Rig's Avatar
Big Rig
Thanks for all of your help...
Big Rig..
Old Sep 24, 2005 | 06:14 PM
captchas's Avatar
captchas
Guest
please be safe. as you are going into something more like a war zone.
