Oil pressure sending unit
Old Sep 21, 2005 | 05:34 PM
penman39's Avatar
penman39
Question Oil pressure sending unit
Hi,
I have a 93 XLT SuperCab with the 4.0L V-6. The oil pressure gauge hardly registers. Other than going to a Ford dealer for a new unit, do any of you know where to get another sending unit? Thanks for your help.
Old Sep 21, 2005 | 07:52 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
You can probably get one at NAPA or most larger auto stores. The Ranger sender is more like an on/off type sender. It does not read actual oil pressure PSI signals. If the sender sees a few pounds it sends the gauge to the middle until it sees no oil pressure. It is a good indication at start up that there is some pressure, but should not be confused with a real gauge that reads high or low corresponding to actual oil pressure.
Old Sep 21, 2005 | 08:35 PM
slmann's Avatar
slmann
I got one for my 86 ranger at Advance auto , I would think that it wouldn't be that hard to find.
