creaking noise
Old Sep 21, 2005 | 05:03 PM
Oley's Avatar
Oley
creaking noise
I have had a loud creaking noise forever now. its getting worse. not radius arms
sounds like center of truck. Any ideas.
88' 150 - plain jane 4x2
Old Sep 21, 2005 | 05:19 PM
jjg052590's Avatar
jjg052590
Well, That topic doesn't fit in here so not many people will see it and be able to help you...
Old Sep 21, 2005 | 05:21 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 21, 2005 | 07:32 PM
McLeod's Avatar
McLeod
Creaking noises could be loose rivets in the crossmember/frame under engine.
While staionary, have someone turn steering wheel while you check it out.
Old Sep 22, 2005 | 02:26 PM
hotstang's Avatar
hotstang
Try the transmission crossmember
I re-torqued all of the bolts on the transmission crossmember and it fixed all of my popping and creaking.
Old Sep 23, 2005 | 12:00 AM
TriumphBoy's Avatar
TriumphBoy
Creaking
Check your leaf springs. Mine have plastic in between that help the springs slide, and a few pieces have fallen out on the right hand side - which makes the spring creak really bad unless I oil it.
A.J.H. 1994 F150 red, 4.9, e4od, overload springs, posi.
