codes and exhaust
Old Sep 21, 2005 | 01:37 PM
05SD's Avatar
05SD
codes and exhaust
Well i fixed my diagnostic port problems and it was just a fuse. Checked the codes and it has a PO402 EGR Flow Excessive. Is this a bad EGR valve or possibly something else? Also my truck has 2 what looks to be Cats on it, are they both cats or is one something else? Both pipes from the manifolds go into the first one and it comes out 3" and goes into the other cat and then comes out int 2 1/4" then goes to the muffler which is missing. I would really like to make this sound better because it is really quiet even with no muffler. What kind of exhaust systems have you guys put on? Thanks for all your help.
Old Sep 21, 2005 | 02:04 PM
MemOrex's Avatar
MemOrex
Could be a stuck EGR valve, bad EVP sensor, or bad EVR. Remove the vacuum line off the EGR valve when the truck is idling. THere should be very little to NO vacuum at idle.
As for exhaust, I took cats off and put 3" pipe with flowmaster. Sounds SWEET. Check my galler for pics.
Old Sep 21, 2005 | 02:42 PM
johnsonswamp's Avatar
johnsonswamp
Depending on where you live, gut one cat (taking the center out and leaving the case on), try it and if you still want it louder, gut the other one. Then with 3" pipe back to a flow master 40, with dual 2 1/2" pipe out the back or a single 3" pipe out the back, it will sound great either way.
Old Sep 21, 2005 | 04:52 PM
EPNCSU2006's Avatar
EPNCSU2006
I wouldn't recommend messing with the cats on a '96 since it is OBD-II. It'll have a constant check engine light. I think that the OBD-II trucks used a differential pressure valve or something to that effect to view the actual egr flow. The valve is either stuck open or opening too much (or excessive exhaust back pressure as a distant possibility) when it is open. Start testing sensors with a multimeter and see if you can find one that doesn't act like it is supposed to.
Old Sep 22, 2005 | 04:18 AM
05SD's Avatar
05SD
Thanks for the info guys. I don't have to worry about cutting cats off where I live so that is an option. as for the check engine light will it still come on if I have the o2 sensor still in the pipe after the y?
Old Sep 22, 2005 | 05:59 AM
EPNCSU2006's Avatar
EPNCSU2006
Yes, it will still come on because the computer monitors catalyst efficiency.
Old Sep 22, 2005 | 12:10 PM
MemOrex's Avatar
MemOrex
Just plug in a MIL Eliminator in the o2 sensor after the cats. It'll send the correct readings to pcm.
