Power Steering Bracket
Old Jun 14, 2002 | 10:12 PM
RK1911's Avatar
RK1911
I need a power steering pump bracket, and the crankshaft and water pump pulleys that fit on a '69 era small block (My engine is a 302) I purchased a complete truck (73 F-100) w/ non-running engine and swapped in the engine/tranny from a '75 F-100 i was restoring due to our liquid sunshine here in washington. the old truck had manual steering, and the '73 had power steering, but the bracket did not come with the "new" truck as the engine was half torn apart on the mounts. When I looked at the pump I had, it had part of a bracket on it, and it looks like it might bolt on the water pump like the alternator does, using the same type of "arm" and belt tensioner. Please let me know if anyone has one to sell, or knows a place online to find one.
Old Jun 15, 2002 | 09:22 PM
tooogood01's Avatar
tooogood01
I would try Denis Carpenter.
Old Jun 15, 2002 | 10:42 PM
jsworkman's Avatar
jsworkman
on a 302 the power steering dose bolt to the water pump but you have to have a water pump for power steering they have two bolt holes that are cast into the pump any braket should work of any truck or car with power steering
Good Luck
John Workman
76 F250 Crew Cab Short Bed 4X4
Old Jul 26, 2002 | 06:20 AM
docholiday72tx's Avatar
docholiday72tx
Can you tell me what that bracket looks like? Does it look like the 390 bracket that goes over the top of the p/s pump, or is it a flat plate that goes in front of the p/s pump?
Old Jul 26, 2002 | 09:43 AM
Mil1ion's Avatar
Mil1ion
zthayer
23
Aug 10, 2014 03:09 PM
flip4eva83
Nov 14, 2011 10:38 AM
kmacht
Sep 15, 2009 09:02 PM
