tilt column
Old Sep 20, 2005 | 03:33 AM
johnanthony1967's Avatar
johnanthony1967
tilt column
has anyone installed the 73-79 tilt column from Bronco Graveyard in a 67-72. I emailed the guy and he said " It will not fit in your truck". I am pretty sure columns up to 79 will fit, just have to figure out the wiring. My truck does have P/S. Is this guy wrong or what?
Old Sep 20, 2005 | 05:48 AM
jowilker's Avatar
jowilker
John, The tilt was available in 78 & 79 in Larait (sp) trim Bronco & F series pickups. If you have the Ford/Saganaw power steering gear (73-79) installed in your truck, it will fit.
John
Old Sep 20, 2005 | 05:14 PM
limegoldf100's Avatar
limegoldf100
The diameter of the column is slightly larger than the cutout at the bottom of the 67 through 77 dashes, but it basically fits.
Old Sep 20, 2005 | 06:01 PM
1975Ford's Avatar
1975Ford
The steering column mounting bracket are the same for the 67 thru 72 Ford trucks and are different than the mounting bracket on the 1973 thru 1979 Ford trucks.
Old Sep 21, 2005 | 06:49 AM
limegoldf100
It's true that the brackets on the dash are different, but the part welded to the bottom of the column is the same.
Old Sep 21, 2005 | 11:25 AM
fitzwell's Avatar
fitzwell
column will fit, no problem, as long as you have the saginaw (later) style gearbox. Wiring is a little different(color codes) Not hard to figure. Install a new rag joint when you make the swap
