HELP! Steering column removal!
Old Jul 26, 2002 | 05:25 PM
RustyF250's Avatar
RustyF250
Re-posting this message since I didn't get a response last time. I need some info as the truck is currently in pieces. Thanks.
The shift collar on my 75 F250 decided to die. Finally have that replaced but now I seem to have another problem(s). The steering shaft now has a lot of axial movement (over an inch I'd guess). My questions are:
1: What part in the steering column takes up the thrust (axial movement) of the steering shaft? Is it the rag joint or is there something else inside the column?
2: If it's something other than the rag joint, how in the heck do I get this column out? I must admit I'm also having quite a time getting the linkage loose from the arm just outside the cab (under the brake booster).
3: Anyone know where I can find an exploded view of this steering column? I have an old Chiltons manual but it's less than useless.
Old Jul 26, 2002 | 05:30 PM
Mil1ion's Avatar
Mil1ion
Undo shifter arm at either on column or tranny.
Undo bolts at rag joint
Undo 2-3 bolts at dash
Undo 4 bolts at firewall
Unplug connector
Pull out
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 26, 2002 | 05:33 PM
Mil1ion's Avatar
Mil1ion
