i have a 87 f 150 and i went over some real bad bumpy roads today and lost power steering, when i got home i saw that the bottom shaft of the steering box had come down about a 1/8 of an inch. how do fix this? and can i drive this way?
thank you ucls1@iserv.net
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
yes that is the shaft, i lost all power steering fluid, and i can see the moved odwn about 1/8 of inch
The only way the Sector Shaft can move down is if the Sector Shaft Adjusting Screw broke or the ears that hold the Adjusting Screw broke off from the Sector Shaft. This would not cause a leak if it moved down only an 1/8 inch. I would look for a crack in the housing.
i can see the snap ring and the o ring groove, from under the truck
This is what we are talking about, right?
Are you talking about 7 or 9.
I do not know of any "O" ring in the botom, it has seals in the bottom but no "O" ring.
Is the Retaining Ring (snap ring) out?
number 7 the shaft where the pittman arm hooks to, is leaking fluid, and looks like it a bout an 1/8 down from the housing.
thanks
