Charging system problems
Old Sep 18, 2005 | 12:21 PM
lmhans4440's Avatar
lmhans4440
I have a 1978 F-150 2wd with a 300 c.i. engine. The amp light will flash on and off rapidly while driving, if you pull out the headlight switch it stops. I have installed a new alternator, and voltage regulator, and nothing changed. A voltmeter test read 16 volts at idle. The headlights also flicker or pulsate. I am stumped. Please help. Thanks
Old Sep 18, 2005 | 04:10 PM
Greg 79 f150's Avatar
Greg 79 f150
Check to be sure the ground to the voltage regulator is solid. Sometimes on old trucks the ground bonding jumpers come loose/break from chassis to body/engine to battery, etc
Old Sep 18, 2005 | 05:34 PM
lmhans4440's Avatar
lmhans4440
Thanks greg, I'll try wire wheeling all connections/ground straps and make sure they are present/tight.
Old Sep 19, 2005 | 01:42 AM
Torque1st's Avatar
Torque1st
Posting Legend
Measure for a voltage across each ground joint.
