Banks Transommand?
Which trans does my truck have; E40D, or 4R100 or how do I tell and has anyone used this kit to improve towing performance?
This is my fourth Ford since 77, had two chevys in between(oops) and is the best truck I've owned to date.
JD3
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved member notified
I would look into a tranny temp guage as well. You're well within towing capacity range but since you are on the higher side of it, a tranny temp guage can certainly prove invaluable to the longevity of your tranny.
You can firm up your shifts electronically with the Transcommand or aother tuner or you can do it mechanically (recommended) with a Diablo Shift Valve or Sonnex Shift Valve. All work well. I prefer mechanically.
Anyway...you probably knew all of that.
I really just wanted to welcome you to FTE.
I've never used a Transcommand but from the many that I know who DO use it (albiet in Super Dutys) it is a great addition to a truck that tows.
I would look into a tranny temp guage as well.......
I have a 2004 5.4 screw, Auto ....Transmission????
Thanks for the info!
