Injector Vacuum Switch
Old Sep 17, 2005 | 10:17 PM
SMACUSTOMS's Avatar
SMACUSTOMS
1985 6.9 Diesel.how Do You Adjust The Vacuum Switch On The Right Side Of The Pump?i Read The Threads On What The Vacuum Readings Should Be.do You Loosen The 2 Screws Where The Plate Is Slotted,or Do You Pull Off The Cap Where The Vacuum Lines Are,thank You
