Need INFO on removing headlight Assembly
Old Sep 17, 2005 | 05:06 PM
ATOWN's Avatar
ATOWN
Exclamation Need INFO on removing headlight Assembly
Hello, I've got a 1994 F-150. I purchased some aftermarket headlights, side turn signals, and bottom turn signals for my truck. I'm having a very difficult time getting that assembly taken apart to replace the factory lights with the aftermarket ones. I'm looking for any information on how to get the old lights out. If anyone knows where I might find information on how to take these lights out, or if anyone knows how to take them out and think they can explain it for me I would appreciate any help I can get. THANKS!
Old Sep 17, 2005 | 05:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of specialized tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Sep 17, 2005 | 07:16 PM
quicklook2's Avatar
quicklook2
this is a perfect example of a repeated question.
covered a hundred times before.
use search, or just go back a few weeks and you will find the answer to this question.
so a faq section will help?
maybe.
Old Sep 17, 2005 | 09:25 PM
brown 4x4's Avatar
brown 4x4
There's two 7/16" nuts on the back of the parklight assembly. They're kind of tricky to get at. Remove them, pull out the parklight assembly and remove the sockets. Remove the grille. Remove all the 8 mm screws holding the headlight/grille support, unplug the headlights, and remove the assembly. There's three clips holding each headlight to the support. A screwdriver and pliers works to get them off.
Not too hard of a job at all. The worst part is those nuts for the parklights. Good luck.
Old Sep 18, 2005 | 12:13 PM
ATOWN's Avatar
ATOWN
Thanks for the Info
I've been able to pull the 2 top clips on the headlight, but I haven't been able to get to that third one. It's quite a way down and I haven't been able to figure out how to get to it. I'll try to get that lower parking light off first and see if that helps. I was trying to pull the headlight first. I have found that inside nut on the lower parking light (the one closest to the grill), but I haven't found the other one yet. I'll get in there and start diggin around again and see if I can get to it. I had a 93 Ranger before I got this truck and the whole front end, lights, grill, etc was a lot easier to get off. I was hoping this would be as easy, but it has proven a bit more difficult. Thanks for the help though!
Old Sep 18, 2005 | 12:24 PM
MemOrex's Avatar
MemOrex
You have to get the parkin lense (the amber one) off first before removing the headlight. Yea, i agree..changing lenses and those 2 corner bulbs is a pain.
