Seafoam Cleaner
Old Sep 17, 2005 | 02:55 PM
kevinyose's Avatar
kevinyose
Seafoam Cleaner
I HAVE A 1998 FORD RANGER DUAL PLUG I RAN A CAN OF SEAFOAM IN IT AND SEEN A BIG DIFFERENCE GOD FOR ALL TRUCK'S WELL WORTH THE MONEY AS GOOD AS FUEL INJECTION CLEANING AT GARAGE LIKE I DONE A FEW YEAR'S BACK
Old Sep 17, 2005 | 07:40 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Did you put it in the gas or directly into the intake? What kind of improvements did you see?
Old Sep 17, 2005 | 09:16 PM
wresleu's Avatar
wresleu
kevin
i agree. I run SeaFoam through everything I own once a year. My Ranger, my Aerostar, my Explorer, my 3wheeler, and even my boat (which is a 2 stroke). I fell in love with the stuff years ago. I first discovered it when I was having troubles with my old motorcycle carbs, things would need cleaned every spring. I started using SeaFoam the first tank of gas every spring and never had to clean the carbs again. Good stuff.
I always just add it to the gas, never heard of running it through the intake...hmm may have to try that on the 200,000 mile Aerostar.
Old Sep 17, 2005 | 10:22 PM
62 red truck's Avatar
62 red truck
SEAFOAM is a very good product.I think it is made in three forms.The fuel/injector cleaner can go in the tank or into a large vac line like the brake vac line only 1/2 can.Trans tune 1/2 can a 100 miles or so before fluid change the other 1/2 can after change.I would hesitate to use this in older poorly maintained trannys.Sometimes the gunk is the only thing keeping them going.Fuel stablizer add a couple of ounces to fuel for storage,like lawnmowers,snowblowers.
Old Sep 17, 2005 | 10:25 PM
ford390gashog's Avatar
ford390gashog
seafoam is made of only 2 things a very light 20w oil and alcohal thats all . i would not consider using it. but thats just me.
Old Sep 20, 2005 | 10:17 PM
62 red truck
Called Seafoam Mfg today in MPLS,MN.The sales rep said you are not correct in your statement.To bad I have 2 bottles of JIM BEAM and some 20 wt oil,there goes my get rich plan.I can use the oil in my truck but what will I ever do with the J B?
Old Sep 21, 2005 | 02:40 PM
kevinyose's Avatar
kevinyose
sea foam
IF WE DONE OUR HOMEWORK SOME PEOPLE WOULD HAVE KNOWN BETTER BUT WE ALL HAVE OPINIONS
Old Sep 21, 2005 | 04:38 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
One of the nice things about running lots of cleaner of any brand through the intake is that you can look forward to replacing your spark plugs . As for what to do with the JB, I'd suggest mixing with coke, 7-up, or using a shot glass and nothing else .
Old Sep 21, 2005 | 10:53 PM
pawpaw's Avatar
pawpaw
Seafoam is pale oil, napatha, & isopropyl alcohol!!!!
On the JB, if you're a glutton for punishment, pour a shot glass full, then sink it in a beer mug of your favorite brew on tap. Chugalug the brew, at the bottom you get the shot of JB.
It's called a Depth Charge!!!!
Most folks don't stay conscious long enough to finish the second one LOL
You definately don't want to do this & try to drive!!!!
Old Sep 21, 2005 | 11:44 PM
JD717's Avatar
JD717
ok, gimme a depth charge, that sounds like a challenge to me. lol.
Old Sep 22, 2005 | 06:31 AM
62 red truck
Thanks for the laughs,if we don't laugh we cease to be human.
PStruwing
Dec 9, 2012 03:02 PM
darsacal101
Mar 9, 2008 08:35 AM
mdpitt
1997 - 2003 F150
Sep 12, 2007 08:33 PM
Sid Daley
Jun 9, 2005 04:23 PM
