hi need help
Old Jul 30, 2002 | 12:32 PM
Juicemaster's Avatar
Juicemaster
hi need help
and i was wondering i dont have lock out hubs when i was stuck the transfer case front drive shaft was not spinning the rear one was but when i put it in 4 low theres a differentence but still no 4wd in reverse so i dont think its the linkage what do you think it work in forward only
Old Jul 30, 2002 | 03:53 PM
76_F150_390's Avatar
76_F150_390
hi need help
Old Jul 31, 2002 | 12:42 PM
sideout2's Avatar
sideout2
hi need help
Did you put it in 4low or 4low lock. All four wheels will not spin unless you are in lock. If you are just in 4hi or 4 low the tourqe is supposed to switch between the front and rear tires depending on which has traction. Also someone may have converted the transfer case to part time in which case in 4hi and 4low only yhr rear tires will have power. do your front hubs have a solid cover or a switch? solid cover means you have full time hub and the front axle is always turning(a designed) if you have a switch the someone has converted it.
