1976 VIN question
Old Sep 17, 2005 | 09:07 AM
Diesel Digger's Avatar
Diesel Digger
1976 VIN question
i'm having trouble identifying the powertrain on a 76 f 150 i'm looking at buying. first 6 digits are F15MP3 trans G Axle 14J. i checked with the link supplied in the VIN forum but trans and axle came back unknown and engine came back as 390 but i didn't think M was a 390. any help would be greatly appreciated. thanx
Old Sep 17, 2005 | 09:27 AM
MBBFord's Avatar
MBBFord
Try another vin # identification site, but if it's 4wd then it's D44 up front, and 2wd or 4wd it's a Ford 9" out back. If it's automatic, it's a C6 trans, and the M was only on 351M400 blocks.
I know other people could look up the vin # for you but I can't find my marked site, and I don't know how much info they could give you with only the 1st 5 #s.
Old Sep 17, 2005 | 12:17 PM
76supercab2's Avatar
76supercab2
Since 351M/400 engines weren't available in 1976, I doubt that engine code M referrs to that family.
F15 = 2wd F-150
M = 390 4 barrel carb
P = assembled in Twin Cities
3 -- there is not a number in that location in my book. That is the start of the consecutive serial number. It could be a 'B' which would cover the December 75 thru March 76.
G = automatic. A C-6 would be behind the 390.
14 = 3.00 rear gears. Not sure what the J means. No J is listed in the axel codes.
Old Sep 17, 2005 | 04:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
J means power steering.
Old Sep 17, 2005 | 05:33 PM
subford's Avatar
subford
M = 390-4V 8 Cyl.
F15 = F-150
G = A.T.
14 = 3.00 NL 3750 Ford
J = w/P.S.
Old Sep 18, 2005 | 09:30 AM
Diesel Digger
thanks for your help everybody. i had another look at the truck and i'm still a little confused. the door VIN says 1976 but it has square headlights. i thought these weren't changed till '78. is it poossible the grill was changed? would it fit? the owner seems to think the engine is a 351. what's the quickest way to distinguish between an FE block and an M block?
Old Sep 18, 2005 | 11:41 AM
MBBFord's Avatar
MBBFord
The grill can be changed pretty easy, as long as you have the headlight surrounds to change form 76 to 79.
You can check the valve cover and see if there is any info still left on there, or on the emisions sticker under the hood, to see if it is a 351M or what.
If you see any info about Liters, then the 351 is 5.8L and the 390 is about 6.2 .
Old Sep 18, 2005 | 06:39 PM
76supercab2
Also, if the intake manifold extends under the valve covers, it's an FE.
