Dash Lights
Old Jul 28, 2002 | 09:33 PM
JUSTOMPONIT's Avatar
JUSTOMPONIT
Dash Lights
When I turn on the right turn signal it flashes but not on the dash.
When I turn on the head lights the turn signal on the dash lights.
Any help on where to start looking.
Left side works fine.
Thanks in advance.
Evan
Old Jul 28, 2002 | 10:09 PM
78f250lj's Avatar
78f250lj
Dash Lights
Check all your bulbs on the right side.
Old Jul 28, 2002 | 10:40 PM
Mil1ion's Avatar
Mil1ion
Dash Lights
Pull your instrument cluster and clean it all up with electrical cleaner.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 28, 2002 | 11:34 PM
dbarracuda's Avatar
dbarracuda
Dash Lights
I would check to see if the sockets were wired correctly if they were ever replaced. Good luck.
David
Old Jul 30, 2002 | 01:51 AM
JUSTOMPONIT
Dash Lights
Thanks for the help.
I will give them a try.
Evan
Old Jul 30, 2002 | 12:02 PM
dfisher1's Avatar
dfisher1
Dash Lights
Just,
You are describing a short circuit. That is, you do not have power to ground.
This could be several things:
1. Bulb is burned out.
2. Bulb socket is worn out.
3. Ground for circuit is bad/dirty/corroded.
This could be the front or rear on the side of concern.
Replace both the socket, the bulb, and clean the ground connection. I find that this repair is simple, when all three problems are attacked at once. That way you don't have to do it again next week.
The socket wears out due to vibration and can no longer make contact with the bulb. If you push down on the bulb and it lights then its the socket. Don't waste your time screwing with it just replace it.
My Way is the Highway,
KingFisher
Old Jul 30, 2002 | 12:27 PM
460FORD's Avatar
460FORD
Dash Lights
i had the same problem just recently - i changed the bulb and,then changed the light socket and that fixed the problem. the light socket contacts were pretty rusty and probably making no contact. when you're replacing the bulbs - check the sockets.
460FORD
Old Jul 31, 2002 | 07:13 PM
Mil1ion's Avatar
Mil1ion
Dash Lights
Old Jul 31, 2002 | 09:28 PM
XLT79Ranger's Avatar
XLT79Ranger
Dash Lights
i had this problem when i replaced my bed. i found it was because the rear turn signals werent grounded and i had to clean a spot for the be to contact the frame. it fixed my problem
