drive shaft
Old Jul 30, 2002 | 04:42 PM
teschwab's Avatar
teschwab
drive shaft
it appears that the driveshaft will interchange between the 351m/c6 and the 302/c6 that im swapping . am i on the right track with this asumption. the truck is a 78 f100 swb
Old Jul 30, 2002 | 05:11 PM
Jimbare's Avatar
Jimbare
all alone in the world
drive shaft
tranny will not move as long as you use the proper mounts. drive shaft should be the same.
Old Jul 31, 2002 | 07:52 AM
teschwab's Avatar
teschwab
drive shaft
i felt that way, but i thought i would ask to be sure. thanks again.
Old Jul 31, 2002 | 04:09 PM
dfisher1's Avatar
dfisher1
drive shaft
All,
When did the 302 come with a C6? Is that a small block C6?
They stop making the small block C6 in 72.
KingFisher
Old Aug 1, 2002 | 09:10 AM
teschwab's Avatar
teschwab
drive shaft
full size econolines can be found with the c6 behind both the i6 and 302/351 well into the early eighties. this particular engine and trans cam from a 1980 e150 chateau. now that the secrets out. have a good day.
Old Aug 1, 2002 | 09:19 AM
Big Bad 1Ton's Avatar
Big Bad 1Ton
drive shaft
