Sponsored by: Real Truck
Ehaust Vibration
Old Sep 16, 2005 | 10:03 AM
sg2005's Avatar
sg2005
Ehaust Vibration
Have an exhaust vibration while the truck is at a stop, does anyone else experience this with there 6.0?
Old Sep 16, 2005 | 10:31 AM
bedwards's Avatar
bedwards
Loosen your connections at the cat and the tail pipe and crank it up, then retighten them. This worked on mine.
btw, the one on my truck was before the cat, somehow it had worked loose
BE
Old Sep 16, 2005 | 10:40 AM
sg2005's Avatar
sg2005
Bedwards I checked all the connections and they were tight. Should i go back and and loosen them and start from there.I called the dealer the tech told me to hit the muffler with a rubber mallet to see if something is loose in the muffler.
Old Sep 16, 2005 | 11:29 AM
bedwards's Avatar
bedwards
I'd loosen them and crank it to shift things around and let things settle, then retighten
good luck
be
Old Sep 19, 2005 | 02:22 PM
sg2005's Avatar
sg2005
Bedwards i did what you said and it didn't work.Want to the dealer today and they are going to order in a new muffler i will give you an unpdate after they install the new muffler.Thanks for your help.
SG
Old Sep 22, 2005 | 08:57 PM
sg2005's Avatar
sg2005
Well the dealer installed a new muffler today and so far no more vibration.
Thanks again for your input.
SG
Old Sep 23, 2005 | 07:41 AM
bedwards's Avatar
bedwards
Had a muffler to collapse internally on a Toyota one time, talk about hard to diagnose!
BE
