standard headlight element blown only?
Old Sep 16, 2005 | 01:55 AM
radio_earbug's Avatar
radio_earbug
This evening my headlights didn't work. Thought my high beems worked. What could cause only the standard lights being blown? Is there any posssible cause for this?
Old Sep 16, 2005 | 02:31 AM
texans's Avatar
texans
the bulb might be bad. I think it is possible to blow one part of the bulb and not the other. I would change one and see if that works. GL
Scotty
Old Sep 16, 2005 | 10:29 AM
87 XLT's Avatar
87 XLT
Dont know what you're driving, but take a look at the fuse page in your owners manual & see if theres a fuse for the low beams only.
Old Sep 16, 2005 | 10:44 AM
Dave257's Avatar
Dave257
There are seperate feeds to the high/low beams. Could be the switch or wiring. What year truck is it?
Dave
Old Oct 7, 2005 | 01:32 PM
jdmattsland's Avatar
jdmattsland
dave, its 2005 hope you are still there.......... my low beams(both) do not work
I have a 95 limited explorer.......
thanks for your help.....
Old Oct 7, 2005 | 01:33 PM
jdmattsland
Old Oct 7, 2005 | 02:08 PM
87 XLT's Avatar
87 XLT
I dont have a wiring diagram for a 95, but this is probably wired from the multi/dimmer switch to a low beam fuse then to the headlights.
Does your owners manual show a low beam fuse? Have you checked it?
Could also be a bad multi/dimmer switch. Simple enough to check that with an ohm meter.
Old Oct 7, 2005 | 03:53 PM
Dave257's Avatar
Dave257
I don't know the explorers, but there is usely two circuits, one for the high and one for the low beam lights. Its a safety issue, so they both don't go out if there is a problem.
Dave
Old Oct 7, 2005 | 08:57 PM
jdmattsland
the fuses are good where can i find the dimmer switch.
Old Oct 7, 2005 | 09:13 PM
jdmattsland
last week the driver side low beam went out, i checked fuse #4 & #8 also switched bulb from pass. side to driver side. it worked on pass side only..........
i took it to a mech. he said i had a short, he said he fixed the problem. it worked for a few days. last night i lost both low beams.
today i checked fuses and they were good. i also noticed that the Mech. just ran a
hot wire from pass. side to driver side. (that was the fix) now both low beams don't work plus my fog light dont work also............i am so getting my money back, i could havd done that and i would haved install an inline fuse....
wher might i find the dimmer switch...... thanks
Old Oct 8, 2005 | 07:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 8, 2005 | 08:51 AM
Dave257's Avatar
Dave257
If someone started "tweeking" the wiring you could have anything wrong. You need to get a wiring diagram for it and trace through it. There are relays, switches, etc in the circuit. I beleive the fog lamps are a different circuit then the headlights so there may be additional troubles there. The dimmer switch is on the turn signal "stock", again you need to talk to someone who knows explorers and has a diagram for it. They are pretty much the same, but there can be differences.
Dave
Old Oct 8, 2005 | 11:06 AM
87 XLT's Avatar
87 XLT
Yep, like Dave sez, nows the time to get your hands on a GOOD set of wiring diagrams. Enter the info for your EX at autozone.com for an online wiring diagram.
maybelle'84
Jun 21, 2019 03:46 PM
Donkey punch
Jun 8, 2014 08:50 PM
RangerDude17
Jan 26, 2014 03:30 PM
got2befast
Nov 6, 2013 12:32 PM
western star
May 26, 2013 10:12 AM
