Howdy, all...
Old Sep 15, 2005 | 08:08 PM
Plain Old Dave's Avatar
Plain Old Dave
Howdy, all...
New here, and getting a 1980 F100 LB either Friday or early next week. It's kind of ratty, but for $350 with a good title and almost no rust I think I did OK. The seller thinks it needs a rear main seal, but I think what we got here is a seriously leaky valve cover gasket that's running down the back of the motor (302 V8). Even if it is, I'll still be ahead of the game after fixing the rear main. Here's what else the truck needs immediately:
-Passenger side door
-door lock and 1/4 window for driver door
-2 tires on front. (off to the Co-Op for them)
Does Ford sell a set with the ignition lock and door locks so they all 3 will take the same key?
Old Sep 15, 2005 | 10:30 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following.
Please view the main forum page to find the best forum to ask any Technical questions.
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
Please post all "items wanted" and "items for sale" in the classified section.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
You have 60 minutes to edit any post made in case there is something you would like to change or add.
Old Sep 16, 2005 | 03:09 AM
RR4E's Avatar
RR4E
The ignition key would be different than the door key is anyways. Just change the door locks as a pair. Look around the wrecking yards in your area for the 1/4 window, a glass shop will charge you an arm and a leg + your firstborn for one. They're not that hard to replace as a unit, either. As for the door, you may luck out and find a whole unit in a bone yard, saving you the time it takes to replace the glass, providing it is in good shape.
