what do you suggest? replace injector - can the wire be fixed
seems to only happen at idol when first started
code does clear once engine has been running
Sounds to me like the injector is failing then....
It really needs a good diagnosis before you go swapping parts though...mine was just an armchair diagnosis.
You probably COULD change an injector if you needed to, but you need to be of the adventurous sort if you've never worked on a 7.3 or 6.0 before.
