Upper Intake Gasket change
Old Sep 15, 2005 | 01:48 PM
MemOrex's Avatar
MemOrex
Im gonna go ahead and pull my TB and Upper intake off to clean them off good and put new gaskets. The TB looks easy to unbolt, but I dont know about the Upper intake. Is it easy? Do i have to take off other parts, or just some bolts? Thanks.
Old Sep 15, 2005 | 02:04 PM
low92flareside's Avatar
low92flareside
I'm pretty sure the Upper Intake is pretty straight forward. While you have it off, I'd take a good look at your EGR tube. The upper intake manifold has to come off to replace it so you may want to do that while you have it apart. Just a thought...
Old Sep 15, 2005 | 02:13 PM
rews2's Avatar
rews2
Yeah, pretty easy I did mine this past weekend I was actually replacing my EGR tube. If I remember right it was 5 standard bolts and 1 #40 torx on the inside of the plenium, need a long extension. I had to pry mine off I guess it had been awhile since it was off last.
