Header Installation
Old Aug 4, 2002 | 07:35 AM
Big Red 75's Avatar
Big Red 75
Post Header Installation
I am in the process of installing headers on my '75 F250 HiBoy with a 390. I purchased Hedman headers made for the application, but they don't fit quite right. The header pipes end right where a frame crossmember is located (right above the area where the front springs mount to the frame. The crossmember is directly beneath the tranny, but is not a mounting point for the tranny.
Is it safe to relocate the crossmember or cut it a bit to make the headers fit?
Any suggestions?
Thanks!
Old Aug 4, 2002 | 08:40 AM
Jimbare's Avatar
Jimbare
all alone in the world
Header Installation
no do not cut the crossmember! if you look it is helping support the rear spring hangers on the front axle. i would return the headers and either get the right ones or my money back.
Old Aug 5, 2002 | 12:41 AM
karljay's Avatar
karljay
Header Installation
Ditto that! Don't cut your truck for a cheap set of headers. They probably set you up with the wrong ones.
Old Aug 5, 2002 | 01:47 AM
Thudpucker's Avatar
Thudpucker
Header Installation
