How many HP
Old Sep 14, 2005 | 07:43 PM
charles jones's Avatar
charles jones
How many HP
I have seen some one in here that has a desk top dyno and wanted to know how many HP my 67 352 at 30 over is. It has a Edlebrock performer manifold. Holley 600 Carb. Hedman headers, stock heads, Pertronix ignition, Pertronix Flame thrower II coil. K&N filter, Ford racing HEI dist. cap and roter, and Ford racing 9mm wires. I put the Jegs high volume water pump on and a 160 high flow thermostat on a new 4 row rad. but I dont think that matters any. Thanks in advance for any numbers ya'll can give me
Old Sep 15, 2005 | 10:37 AM
Mike G's Avatar
Mike G
If you have not changed out any of the internals (cam), I would dump out a guess of 215-225hp.
You can wait for the guys with the computer toys however..
--Mike
Old Sep 15, 2005 | 11:16 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Just useing the DD2...and not having all the spec's with a .500" lift at valve cam? 9 to 1 CR, aluminum intake,600cfm carb, large tube headers (open)
Not counting for Driveline loss !!
390lbs of TQ @ 2000rpm
269hp @4500rpm
These are just ballpark!!
Russ
Old Sep 15, 2005 | 03:54 PM
charles jones
Thanks Russ and Mike, The block is 30 over and the heads are stock. I forgot the 2 1/2 in flowmasters dumped in front of the rear wheels. What CI is it at 30 over if any one knows?
Old Sep 15, 2005 | 04:38 PM
Madmike33's Avatar
Madmike33
You now 357ci.
Madmike33
Old Sep 15, 2005 | 04:47 PM
ford390gashog's Avatar
ford390gashog
i come up with 360 ft pounds at 2k and 216 hp at 4500
Old Sep 15, 2005 | 06:37 PM
RapidRuss's Avatar
RapidRuss
Thats probably close the one I did was gross hp not net....
Russ
Old Sep 15, 2005 | 09:15 PM
charles jones
Thanks gashog and Russ, since this truck is my son's and just for fun I like gross hp numbers better lol
Old Sep 16, 2005 | 07:46 AM
RapidRuss's Avatar
RapidRuss
Anytime Charley!!!
Russ
