lighting problems
Old Sep 14, 2005 | 04:57 PM
735.0Short's Avatar
735.0Short
lighting problems
hello i have 2 problems on my 73 the front lights wont come and the signal lights wont signal but they will come on also i bought the signal cam off ebay but i couldnt figure out how you take off the steering wheel can anyone help or should i just go to the yard a pull a new steering column mine is in pretty bad shape
Old Sep 14, 2005 | 09:45 PM
735.0Short's Avatar
735.0Short
at least can someone tell me how to remove the steering wheel took the nut off but it still seem to be being held by something
Old Sep 14, 2005 | 10:24 PM
witdog2020's Avatar
witdog2020
Steering wheel puller, these are usually a tight fit I have busted pullers trying to remove that wheel. The lights are a tough one to explain could be dimmer switch or dash switch either one, the 73's were bad about the dimmer not getting ground because of the rust under the switch in the floor boards. As for the signals sounds like a bad blinker ?
Old Sep 14, 2005 | 10:31 PM
pfogle's Avatar
pfogle
I'd start by replacing the battery cables. Get the ground cable with the 10 gauge pigtail. Then use said pigtail to ground the body, the best spot is right AT the voltage regulator. This will ensure a good ground for the lighting system as well. Then move on to other things.
Old Sep 15, 2005 | 03:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
There is a tech article here on lights as well as a post in the Read First: FAQ thread at the top of this forum.
