K&N Filter
Old Sep 14, 2005 | 02:49 PM
wojowojo16's Avatar
wojowojo16
K&N Filter
Any thoughts, put one in the truck and not sure if it did anything really. (98 EXP w/ 5.4)
Will it hurt the MAF at all?
Thanks
Old Sep 14, 2005 | 03:45 PM
351cj's Avatar
351cj
I also put a K&N fillter in my 2000 expedition with a 4.6 engine. I did not notice anything differant at all about the truck after installing it. The MAF thing is a total myth UNLESS YOU OVER OIL your filter element when you service it, K&N warns the consumer against over-oiling filter elements.
Old Sep 14, 2005 | 03:52 PM
wojowojo16's Avatar
wojowojo16
thanks for the info. Maybe I should have saved the $$$$
Anybody had luck with a cold air intake?
Old Sep 14, 2005 | 11:18 PM
Icefan71's Avatar
Icefan71
I put a Gibson cat back on my 98 5.4 and didnt really notice a change. About a month ago I put in a K&N filter and now I can feel a difference at highway speeds. A little more passing power and slightly better gas mileage.
Old Sep 15, 2005 | 08:16 AM
kwaskow's Avatar
kwaskow
I did the drop in K&N in the 32valve Intech.....no difference
Old Sep 15, 2005 | 08:40 AM
eric james's Avatar
eric james
The drop doesn't make any difference except in the cleaning intervals. Kind of nice to not have to change the filter all the time.
Old Sep 15, 2005 | 10:23 AM
wojowojo16's Avatar
wojowojo16
the problem I guess was I just went camping in WV...6 People in the truck and towed a 5x8 trailer (loaded about 2.5K pounds total, Im guessing) The slightest incline the truck really struggled...it would kick out of OD and then lose speed in 3rd gear. I guess i just expect more out of a truck with a 5.4L DOHC engine. I know the 99's made more power, I'm just saying with mine.
Old Sep 15, 2005 | 12:28 PM
eric james's Avatar
eric james
Seems about normal. Kicking out of overdrive is normal. What gears are you running? With 3.73's you shouldn't be struggling. My travel trailer weighs in at 4200 lbs and my 5.4/3.73 doesn't complain much.
Old Sep 15, 2005 | 05:39 PM
ExpySport's Avatar
ExpySport
I put a K&N filter in my 02 5.4L Expy and I didn't notice a difference at all. Mileage stayed the same with same type of driving habits.
I read somewhere (perhaps it was here on the forums) that the K&N filter doesn't flow as well as a stock paper filter until it gets dirty. Doesn't make sense to me, but then again, a lot of things don't these days!
Old Sep 16, 2005 | 06:59 AM
wojowojo16's Avatar
wojowojo16
5.4 with 3.73 gears...I have the tow package.
I understand it's normal to kick out of OD but it was still struggling in 3rd gear on some of the hills.
Old Sep 18, 2005 | 05:34 AM
Freak4Ford's Avatar
Freak4Ford
Icefan71 what size in/ out did you use on your catback?
Old Sep 18, 2005 | 03:36 PM
351cj's Avatar
351cj
You should NOT TOW IN O.D. PERIOD !!! Thats the weakest parts of the tranny !!! Read the owner's manuel !! A engine-tranny combo can only do so much.
Old Sep 19, 2005 | 12:46 PM
wojowojo16's Avatar
wojowojo16
it's fine if it's not that much wait and your going flat..
sure, I wouldn't tow a car in OD but a 5x8 trailer's not a big deal.
Why the hell would i run on a straight flat road in 3rd gear at 72MPH?????
Old Sep 19, 2005 | 02:38 PM
ford390gashog's Avatar
ford390gashog
why would you tow in o/d up a hill are you crazy??????????????????
Old Sep 19, 2005 | 02:44 PM
ford390gashog
well add it up your entire load and trailer put you into the 10,730 gcwr curb weight 6200-gas 180 lbs people about 750 lbs extra cargo 100 lbs 5x8 trailer 1,000 lbs + 2.5k in trailer =10730. you should not have been in o/d the entire trip. even on flat roads that is to much for hte o/d.
