random misfire
Old Sep 14, 2005 | 12:57 PM
Wit-in-MN's Avatar
Wit-in-MN
random misfire
I have a 93 f-150 302, i have a random misfire under load. I have changed plugs, wires, cap, rotar,PCV valve and fuel filter and it still persists. I am curious to see if anyone has any more insight for me.
Old Sep 14, 2005 | 02:42 PM
estalder's Avatar
estalder
Make sure your 7 and 8 plug wires are separated. I used to have that problem on my '92 with the 302 and changed the plug, wires, cap, and rotor, and still had the random misfire under load going up hill. After reading these forums I discovered that the number 7 and 8 spark plug wires have a tendancy to crossfire, and once I pulled them out of the spark plug wiring harness, and put a little distance between them all is OK now.
Hope that helps,
Eric.
Old Sep 14, 2005 | 03:55 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 14, 2005 | 08:28 PM
*92flareside*'s Avatar
*92flareside*
it sounds to me like spark knock.. wich means your timing is advanced to high for the type of gas your running
