Need Alternator Help
Old Sep 14, 2005 | 09:43 AM
digitalrancher's Avatar
digitalrancher
Exclamation Need Alternator Help
I have to replace a bracket that bolts to the front of the engine head on my 72 F100 (302 V8), and to which the alternator bolts. I've been unable to find a used replacement, but I have found someting from LMC Trucks that might fit the bill. However, it doesn't look the same. I hoping someone can reassure me that this is what I need before I buy (see image at http://www.jasek.net/images/altbracket.jpg). I called the sales number, but they seem to just be telephone operators and were unable to provide me with any useful information. Any advice or direction would be greatly appreciated.
Old Sep 14, 2005 | 11:25 AM
thesprocket26's Avatar
thesprocket26
Do these brackets look like your old one? It seems like the right part. IF not, go the salvage yard and pick up a set. They have to be cheap.
Old Sep 14, 2005 | 12:23 PM
4Cammer72's Avatar
4Cammer72
i had a set like that on my 72 before i swapped in the 4.6.
Old Sep 14, 2005 | 02:32 PM
Tech 1's Avatar
Tech 1
Smile
If you are talking about the cast iron bracket that bolts to the front of the cylinder head and also has the dipstick tab bolted to it, then that is not the bracket you need. The bracket in the illustration that you provided is the one that bolts to the front of the water pump and alternator. I guess a junk yard (scuse me) recycling yard would have the bracket you need. Good Luck
Old Sep 14, 2005 | 08:10 PM
charles jones's Avatar
charles jones
If your talking about the bracket on the front of the alt. that the adjustment is on. I got one at the parts store that was chrome and had a arc in it and cut it off with my chop saw as it was to long and then redrilled it to fit
