Winshield washer switch sucks
Old 09-15-2005, 09:08 AM
CJK440's Avatar
CJK440
CJK440 is offline
The push button on the end of my turn signal stalk sucks. The washer pump doesn't run unless I push hard on the button. My 95 Mustang had a similar problem.
Is there an easy fix?
Old 09-15-2005, 09:13 AM
lancekilgore's Avatar
lancekilgore
lancekilgore is offline
try spraying some wd40 or other lubricant in there, lots of times junk gets in there and when the lub is applied it cleans it up and normally works.
Good luck
Lance
Old 09-15-2005, 12:30 PM
christaylor's Avatar
christaylor
christaylor is offline
Do a search on multi-function switches. they have been discussed a few times. Seems easy to take apart and clean.
https://www.ford-trucks.com/forums/s...unction+switch
Old 09-15-2005, 05:50 PM
triton_2002's Avatar
triton_2002
triton_2002 is offline
Check this out for step by step instructions:
https://www.ford-trucks.com/forums/s...connectbattery
Old 09-15-2005, 06:59 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
FordTrucksKickGM is offline
You dont say what year your truck is. My 99 F150 had a recall a few years back for the wiper switch. It would kick the wipers on for like one cycle out of the blue. Ford replaced the switch for free. Check the recalls section on here to see if it affects your truck.
