1978 - 1996 Big Bronco
Clicking
Old Sep 13, 2005 | 09:27 PM
bryang's Avatar
bryang
Clicking
Can anyone help me out, I have Warn 4WD manual hubs that click locked and I am moving. I have replaced all the u-joints, and wheel bearings. Any help would be appreciated.
Old Sep 13, 2005 | 09:37 PM
Evan III's Avatar
Evan III
Check to make sure the hubs are fully locked. You can do this by jacking up the front, ( on jackstands) lock one side and rotate the wheel, you should see the axle turn if it is skipping you have a bad hub. Do this on both sides. Also it is really easy to take the hubs off, All you need is an allen wrench a small flat head and a small pair of needlenose pliers. Snapring pliers come in hand, but you don't really need them. Take the screws out of the cover remove cover and check out the insides to make sure they are working. Good luck
