Getting 4.56 gears, should i replace both lockers???
Old Sep 13, 2005 | 09:26 PM
cesardajr's Avatar
cesardajr
Question Getting 4.56 gears, should i replace both lockers???
im getting new front & rear precision gears 4.56's since i have 35's. im also getting a new auburn gear locker in the rear, should i change the front locker also? the install shop says not to change the front because it does not need it, what do you guys think? has any one change out both lockers when upgrading to 4.56 gears? how does it handle now? what about the front end?
Thanks
Old Sep 13, 2005 | 10:11 PM
propaneguy's Avatar
propaneguy
I would think of putting an air locker in the front. Full time posi in the front makes it difficult to turn sometimes, especially on icy surfaces. With the air locker the differential is locked when you need it and not when you don't.
