Bronco II Ford Bronco II
86 bronco11
Old Sep 13, 2005 | 03:16 PM
hawken50's Avatar
hawken50
Question 86 bronco11
i had a tranny overhaul done on my 86 bronco v6 3 speed with overdrive ,fuel injection. the engine ran great before overhaul but now it runs lousy it misses, acts like it loads up and dies when comes to a stop unless rpms are kept high. my question is - what would the connection be if any, between the overhaul and engine running badly? are there any sensors that need to be changed or replaced or vacumn lines that should be checked
Old Sep 13, 2005 | 03:24 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Check the vacumn line from the left side of the uppr intake that runs to the top of the tranny.its matel and has rubber ends.I would check All vacumn lines then if thats not your problem'pull the codes.{check tech thread at top of B2 page on how to do this}
Old Sep 13, 2005 | 07:39 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Sounds like they didn't get it back together right, follow Gray's post.
