Vacuum Modulator
Old Sep 12, 2005 | 09:09 PM
SMACUSTOMS's Avatar
SMACUSTOMS
Vacuum Modulator
I Have A 85 F250 6.9 Diesel W/c6 Tranny.i Would Like To Know What The Different Color Stripes Mean On The Vacuum Modulator.the Parts House Lists A Green,purple,and Black Stripe.do The Colors Indicate Different Rpm Shift Patterns?any Help Would Be Great.thank You.
Old Sep 12, 2005 | 09:50 PM
good 'ol ford's Avatar
good 'ol ford
yes they do mean different rpm shifts if memory serves right green and black are the highest being that u truck is a desil i would go with a purple and adjust if nessiary
Old Sep 12, 2005 | 10:32 PM
SMACUSTOMS's Avatar
SMACUSTOMS
Thank You Good Ol Ford.it Has A Green In It Now.doesn't Shift Into 2nd Untill 2,600 Rpm.too Much I Think For A Diesel.this Is My First Diesel So I'm Still Learning.thank You Again.
Old Sep 12, 2005 | 10:34 PM
good 'ol ford
u could try adjusting it if u take the vac. hose off and turn the flat screw inside there couter clockwise to lower clockwise to increase shift range
Old Sep 12, 2005 | 10:44 PM
SMACUSTOMS's Avatar
SMACUSTOMS
Thanks For The Info.i'll Give That A Try First.any Suggestions On What Rpm It Should Shift Into 2nd Gear.
Old Sep 12, 2005 | 11:43 PM
good 'ol ford
mmmm really dont know im not a big desil person so u will have to wait on somone else to come along and answer that
Old Sep 13, 2005 | 11:08 AM
DeepRoots's Avatar
DeepRoots
on my diesel c6...
if it's accelerating slowly, it shifts at 2000rpm, only drops like 3-400rpms
if your really rocking it'll shift as high as 2,600rpms
i mean... it's vacuum controlled, so your foot controls the shift points to some extent
you can also adjust the shift points somewhat on the valve which resides on the driverside of the injection pump.
