starter solinoid
Old Sep 12, 2005 | 07:48 PM
mtttricker's Avatar
mtttricker
starter solinoid
on the solioid of a 1989 econoline 150 8cly 5.0 302 what posts do the battery wire and what post does the wire to the starter go ?Iam working on this van with several wireing problems and wondering if this may be one I can get it running with a jump wire on the feul pup relay from the battery It seems like it is the opposite on my 84 econoline would it still run if it were reversed ? thanks Mtttricker
Old Sep 12, 2005 | 07:59 PM
Franklin2's Avatar
Franklin2
There should be some smaller wires on the large lugs with the larger wires. These smaller wires need to be on the same lug that the large bat + wire is bolted. Other than that, there shouldn't be any difference.
