Exhaust
Old Sep 12, 2005 | 04:15 PM
wallace_cody's Avatar
wallace_cody
Exhaust
I am looking to get an exhaust put on my truck. I was wondering if I should put true duals on my truck or just one muffler. What are the pros and cons of true duals. Thanks
Old Sep 12, 2005 | 05:17 PM
2004 Screw's Avatar
2004 Screw
True Duals do wonders for a engine pushing more then 360 RWHP ,and if you do put them on your truck it will be slower off the line
Old Sep 12, 2005 | 05:38 PM
ChrisAdams's Avatar
ChrisAdams
Lots have been posted on exhaust, new thread about once a day, but to recap, if you have a 5.4 you will see more benefit from the 'twice pipes' approach.
On a 4.6, especially one with 3.55 gears, or the 32 inch tires, you will probably get less out of the hole, better on the freeway, or in passing.
It’s very possible you will end up with less power and gas mileage with dual pipes on a 4.6 than with stock.
If you want to save gas/money, assuming a 4.6, try just putting on a Magnaflow or similar muffler, keep the stock pipe, which is pretty big. Keeps the cost down, gives you a good sound, and any actual power and mileage benefit will show.
Putting a cat back single pipe is probably the best power/gas mileage choice on the 5.4.
I put an 18 inch Magnaflow with cat back on my truck, and it was too noisy on slow climbs. I switched to a 24 inch with my cat back, couldn't be happier.
There are many different exhaust setups out there,
Search under muffler, or any brand name you want and there are lots of good posts, including pics and some sound clips.
Chris
