'75 Night Lights!
Old Sep 12, 2005 | 03:02 PM
mswift's Avatar
mswift
'75 Night Lights!
When driving down the road in my '75 hi-boy with my bright lights on, sometimes the lights go completely out and I can't see where I'm going.
It never happens on the low beams, but only high beam. And once I switch it back over to low beams, they start working again. It doesn't happen all the time, but too damn often. One of these days it's gonna happen going around a corner, and I don't wanna rinkle a fender. Any suggestions on what the cause is. Pulling too much juice?
In the meantime, I'm running the Aircraft runway lights for my brights.
Mike
Old Sep 12, 2005 | 03:15 PM
leadmic's Avatar
leadmic
Sounds like a bad dimmer switch to me.
Leadmic
Old Sep 12, 2005 | 03:27 PM
mswift's Avatar
mswift
Never thought of that. I've got a couple extra trucks around, so maybe I'll swap it out for a UOS (Used, Old, Stock)
Mike
Old Sep 12, 2005 | 05:05 PM
fellro86's Avatar
fellro86
either a dimmer or a short somewhere throwing the braeaker, but if all you you do is switch back to lows and it works, it would have to be the dimmer.
Old Sep 12, 2005 | 05:45 PM
perky's Avatar
perky
Mine did that last year it was a dimmer switch.
Dale
Old Sep 12, 2005 | 06:28 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Did you by any chance replace the original bulbs with halogens?
Old Sep 12, 2005 | 06:52 PM
BigShelby's Avatar
BigShelby
The dimmer switch might not be bad though. I had a 73 Dodge D100 that did the same think and what I found was the dirt, moisture and rust had made for a bad ground. After I cleaned it I had no problems. Dimmer switches aren't expensive but this might be the trick.
Old Sep 12, 2005 | 11:08 PM
hotroddually's Avatar
hotroddually
i have had the same problem and it was the headlight switch on the dash.the problem is your lights on high beam cause the wiring to heat up and it tripps a sealed breaker in the headlight switch,the problem will eventually happen on low beam as well.i changed the switch and the problem was solved.its all do to resistance in the wiring,so make sure all the contacts at the dimmer switch, and the headlight switch are all corrosion free.this will help ,and if you replace you headlight switch,up grade to a heavyduty model.hope this helps you out. -billy
Old Sep 12, 2005 | 11:37 PM
rebel_ford4x4's Avatar
rebel_ford4x4
just dont drive with you high beams on, i never do anyway and i dont see much of a difference they make. its just a pain to have to turn off the highbeams every time a car comes in sight.
Old Sep 13, 2005 | 03:16 AM
Torque1st's Avatar
Torque1st
Posting Legend
Flickering on and off can also be caused by a weak breaker in the headlight switch but I agree in this case it is probably the dimmer switch on the floor.
Old Sep 13, 2005 | 09:31 AM
mswift's Avatar
mswift
Thank you all for the recommendations/advice. I will swap out switch on floor first, and make sure the UOS is grounded good. If it continues, I'll throw in a light switch, and make sure sure all terminals are corrosion free on them as well. I'm pretty sure I've got a UOS for it too!
Thanks again!
Mike
Old Sep 21, 2005 | 12:56 AM
mike 77jadegreen's Avatar
mike 77jadegreen
dimmer switch spray with wd 40 work it lots (dim/bright ) fixed a couple over the years like that
