54 Indicator Mounting
Old Sep 12, 2005 | 02:33 PM
Steve_B's Avatar
Steve_B
I bought a new repro indicator switch but it dosen't fit
It seems that at some time in the life of my truck a previous owner fitted a switch and mechanism from a different vehicle
How was the original switch mounted to the column ?
has anyone got a picture of the mounting boss on the column ?
Stephen
Old Sep 16, 2005 | 01:35 AM
Bessie's Avatar
Bessie
The original switch is mounted internally to the column with only the arm sticking out. I suspect that you may have a truck that did not come standard with turn signals and either a dealer or a previous owner installed. Best bet would be to look in the shop manual for part numbers- if nothing there, an American junk yard would likely have what your looking for if you want to go with an original set-up.
Old Sep 16, 2005 | 10:02 AM
Steve_B's Avatar
Steve_B
Thanks Bessie
I have a lead on a 1956 column that I will take a look at
Stephen.
