Throttle Position Sensor
Old Sep 12, 2005 | 08:41 AM
Viper1837's Avatar
Viper1837
I have a 93 F150 with the 302. Do you have to pull the throttle body off to replace the TPS or can you get to it without removing anything but the TPS.
Dean
Old Sep 12, 2005 | 10:39 AM
Firefighter8-1's Avatar
Firefighter8-1
yes you have to pull the throttlebody off, thats the only way to get to it unless you have a reallllllyyyyyy small phillips screwdriver. even then you probably won't be able to get enough torque on it. just make sure you replace the TB gasket when you're done.
