Alternator Help
Old Sep 11, 2005 | 10:33 PM
Nubz's Avatar
Nubz
Alternator Help
I have a factory alternator with all new components, and a battery that wont charge... anyone got any ideas as to why? I've burned up at least 5 alternators, and the problem still wont go away. plz someone shed some light on this matter.
Old Sep 11, 2005 | 10:42 PM
texans's Avatar
texans
you probably have a dead cell in your battery. that would cause it not to take a charge. if I was you I would put a new battery on it. gl
scotty
Old Sep 11, 2005 | 11:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Sep 12, 2005 | 03:53 PM
Franklin2's Avatar
Franklin2
What are voltmeter readings at the battery with the engine off, and with the engine running? Is the alternator light on in the dash when it fails?
Old Sep 14, 2005 | 11:29 AM
Nubz's Avatar
Nubz
12.25 when its on or off. and no the light doesnt come on
Old Sep 14, 2005 | 12:41 PM
Franklin2's Avatar
Franklin2
I don't know what year you have, but most alternators have a fusible link on the output wire going to the starter relay. Follow the large black/orange wire up the harness, and somewhere along the way you will see a rubber thing in the wire. This is the fusible link, and it may be burnt out.
