factory tach
Old Sep 11, 2005 | 12:54 PM
Shovelhead 93's Avatar
Shovelhead 93
Question factory tach
I got a dash out of an 81 f-150 302,put it in my 83 f-150 and it didnt work!! my 83 used to have a six but now has an 8 with the wiring harness from the eight how do i get it to work?? back of dash on tach mounts there is 18GB all on separate terminals Im assuming 8=V8 G= ground B=battery and 1=ignition I am assuming the tach is in working order as the truck didnt run thanx alot
Old Sep 11, 2005 | 01:18 PM
82F100SWB's Avatar
82F100SWB
the 8 and G terminals are grounded in a V8 app, B goes to an ignition switched +12V source, and the I terminal goes to the negative side of the coil.
